buschur racing solid diff mounts. any gain from these?
i am just trying to feel out what they are for other than weight savings.
i recently acquired a set for free. the older version which is all aluminum, not with inserts as shown.
anyone run these and if so what side effects if any have you noticed. my car just hit 100k so i am sure the stock rear bushings are a little worn. which is the main reason i was going to install these, but would like feedback before i do so.
we ran these on the drift evo untill i built the new rear end setup which was all custom using a irs ford 8.8. so we can no longer use these on the shop car.
https://secure.buschurracing.com/cat...oducts_id=1603
I have ran both the solid version and the newer versions with bushings. The solid ones on a street car are noisy as hell. The ones with the bushing are awesome. Just like stock " no noise" but yet hold the rear more ridged then stock. Plus it drops weight. I see only pros with these brackets. No cons. AAA+++ products.
kpt6
Sep 22, 2015 08:40 PM
Evo8564
12
Feb 23, 2006 07:57 PM
intolerance
Dec 4, 2005 06:32 PM
