What motor oil should i use?eagle rods,wiseco pistons, fs635 turbo
Old Jun 21, 2011 | 07:04 PM
MattevoVIII's Avatar
i burned 3 oem turbos in the past, I have no idea why
so finally i got a:
-fp oil feed line from the filter housing
-BR turbo kit fs635
-lower end is built
should i get amsoil 10w40? any better ideas? to protect the turbo and internals?
thank you
Old Jun 21, 2011 | 08:16 PM
gbang's Avatar
I use Amsoil 15w 50 racing oil
Old Jun 21, 2011 | 08:19 PM
Joesforspeed's Avatar
What about some type of oil additive.
Old Jun 21, 2011 | 10:00 PM
Fabguy's Avatar
amsoil seems to be the new blend of choice again as of late
Old Jun 22, 2011 | 05:58 AM
apagan01's Avatar
No need to use any oil additive, at least i wouldn't
Old Jun 22, 2011 | 06:57 AM
Paintballguy's Avatar
amsoil ftw
Old Jun 22, 2011 | 09:05 AM
Dallas J's Avatar
Veteran: Army
http://store.forcedperformance.net/m...otor%20Oil.pdf
I use 10w-30 Valvoline VR1 in the Evo and 20w-50 in the Talon.
Old Jun 25, 2011 | 09:18 PM
CO_VR4's Avatar
The additive package is very important. High zinc and phosphorus are the important components to look for to keep your motor and turbo properly lubricated.
The zinc and phosphorus additives were removed from most street oils due to emissions effects a few years ago. You can only get high levels in oils that are specified for "off-road" type use.
Old Jun 26, 2011 | 07:27 AM
CO_VR4's Avatar
Not quite true.
Amsoil makes a good product, but as you can see from reading the FP chart, a large number of their oil types are NOT recommended (just as the other manufacturers) because they do not have the additive package that includes the high zinc and phosphorus additives.
The ONLY recommended oils are the ones with the high zinc and phosphorus additives That's where you start. After that, you can pick the oil supplier of your preference, so long as they offer an oil with those additives.
Old Jun 26, 2011 | 01:11 PM
1NastyMR's Avatar
15-50 Mobil One, No issues here
Kidloco51
Jan 9, 2023 10:06 AM
stefano
Midwest Region
May 11, 2010 08:42 PM
Nick@Buschurs
22
Apr 29, 2009 12:00 AM
SlowEvo-IX
Mar 16, 2009 03:07 PM
TurboRSX04
Southeast Region
Dec 13, 2008 02:03 AM
Quick Reply: What motor oil should i use?eagle rods,wiseco pistons, fs635 turbo
