Tial 44mm WG?
Tial 44mm WG?
Hi Guys,
just wonder will a Tial 44mm MVR WG works better for my setup compare to my current 38mm turbosmart wg?
Evo engine
2.0L
GT3076R - Low boost 1.5 bar High 1.8 bar
Lastly, will the 44mm wg big enough for my setup and will it reduce backpressure?
Sorry for the noob question.
Evo engine
2.0L
In my opinion, you won't see any difference between the two on your setup. If your current WG is working fine I would just keep it; not to mention going from the 38mm to the 44mm is not a straight plug-and-play deal as their flanges are different. The 38mm WGs are proven to work on high HP applications.
Some say, it is due to unsufficient discharge area of the exhaust gases.
Hi Cali, thanks for sharing but the reason i thought of swapping is to reduce the turbo backpressure as i noticed the exhaust manifold were tremendously hot spreading from the turbine hot side up toward the exh manifold.
How are you measuring the temps on the manifold? What kind of material is the exhaust manifold you currently have? The wastegate would not cause backpressure issues let alone cause the temps to rise in the manifold; If your exhaust temps are really high, check your EGT levels; running lean would cause EGTs to rise noticeably.
a wastegate can not decrease back pressure, only turbine A/R/larger ID manifold/larger exhaust etc
a given backpressure is required to run a given boost on a system, you can not lower it with a wastegate, if you drop the backpressure you also drop boost
okevolutionVIII
Nov 19, 2013 11:22 PM
