My goal is 450hp and 350-375tq, what my moves to get there
#31
Not quite sure. Thinking it was a spark issue.
Great Point Chad! Sorry I overlooked that. I was running another shops tune on the car when it died. The car is now at CBRD in the beginning stage of a new build.
#32
you certainly do not need a ported head for your horsepower goals. Stock size valves, with our pocket port is all you need.
check it out.
https://www.evolutionm.net/forums/ve...-shipping.html
check it out.
#33
check it out.
check it out.
#35
And to be honest, it's not all going to be in the head. It helps you have a good tuner that has the ability to help make those things a reality.
#36
I currently have on my car (Evo IX MR) the following:
Exedy Twin Disc
ETS UICP(short route) & LICP V.2
AMS FMIC (newer version)
Kelford 272s
GSC (or Supertech) Valves Springs, Retainers, & Seats
FP Black Ported w/ 25 wastegate w/ oilline
Buschur Ported Polished Exhaust (coated) & Intake manifolds.
Buschur Ported TB
Tomei Expreme 02s Housing & Downpipe (Coated)
Apexi' Noir Exhaust
AWD Aluminum Driver Shaft
Forge BOV
Forge MBC
Megan Test Pipe
Walbro Fuel Pump
1000cc Injectors
there's more but I'm too lazy to type the remaining. On pump I made 405whp and 364 ft/lbs @26psi on an FP Green HTA; that lasted a month until my Black came in. I now make 461whp and 380 ft/lbs @ 25-26 psi on pump (93). No knock. Totally smooth. Stock block with 63K. AWD Motorsports did the tune and installed everything. LOVE AWDMotorsports!
Exedy Twin Disc
Kelford 272s
Buschur Ported TB
Apexi' Noir Exhaust
Forge BOV
Forge MBC
Megan Test Pipe
Walbro Fuel Pump
1000cc Injectors
#37
So you're saying get a black?
I do like my bbk and the spool is quick. Black is a little laggy. Im not against for by no means but I don't know if I have the heart to walk into cbrd and ask Chad to rip out the bbk and slap in a black, haha.
Idk yet but on the head, I probably will get headgames with gsc s2s, gsc valvetrain and maybe go with a bbkb.
But the bbkb might be at a later date.
I still need a brake upgrade, eventually a clutch, and some tires. As for now that's the priority list
Exedy Twin Disc
Kelford 272s
Buschur Ported TB
Apexi' Noir Exhaust
Forge BOV
Forge MBC
Megan Test Pipe
Walbro Fuel Pump
1000cc Injectors
Exedy Twin Disc
Kelford 272s
Buschur Ported TB
Apexi' Noir Exhaust
Forge BOV
Forge MBC
Megan Test Pipe
Walbro Fuel Pump
1000cc Injectors
#41
I wouldn't consider the black or fp. Cbrd and bbk is where I'm at. Maybe a bbkb, or when Chad gets that dual ball bearing monster, or whatever he has new and better.
#42
Rockman you also have a built motor to handle the power of a black. Yes I know they get ran all the time on stock blocks but it is my DD and I don't want to risk breaking anything. I saw your YouTube dyno and yeah u got a sick car, but I'm in search of being on the side of reliability, practical, with quick spool, yet putting enough power to reach my considerable goals.
Anyway sick car rockman, just not for me.
#43
#44
![Stick Out Tongue](https://www.evolutionm.net/forums/images/smilies/tongue.gif)
