Tomioka Racing TD06-20G
Exactly. I am on a budget. I wish I could afford a DBB Green. All in due time I guess. I thought about picking up a IX turbo, but something came up that cost about the same as a new or rebuilt IX.
With that said, a few weeks ago I purchased a Kando Dynamics TD06SL2 20g. It came with install kit, an 18psi wastegate actuator, and 3in surge ported compresssor cover. While doing some research, I found out that the compressor and turbine wheels measure in exactly the same as the Tomei ARMS turbo. Also, it seems that people and shops all over the world are using the Kando internal parts and turbine housings in their own fabrications. I will install it next week and will post back in this thread with my thoughts.
My first car when I was 17 was a 2g turbo DSM. I fully understand about cheaping out. 2 DSM's, an Evo X, and now an Evo 8 later, i'm still here.
I did a ton of research prior to buying this turbo and i'm not too sure if its built cheaply. Like I stated earlier, lots of people use Komak turbo parts including vendors on this very website. I'm pretty sure all will be ok. If not, i'll throw my stock turbo back on and call it a day.
Sounds great dude,please update as soon as you can,would love to see a dyno chart,i have been considering different update options to my IX turbo as opposed to the other higher priced ones out there,i wouldn't mind trying this to stay under budget,thanks for the info.
Any updates on your Kando 20G install?
cheers
Arthur
I hear ya man. I like to go out and try new things out also. Thats how people learn. Uve stated you done your research and are on a budget, so that tells eveyone ur not going to be dropping 2500k on a turbo right? If i recall correctly, lots of people thought the the FPwhite ( not bunny) was a waste when it cam out, and i found it to be a good upgrade for the 700 buks i spent. Used even. Anyway, let us know how it turns out. Get an open dump o2, or at least get one of MAP's routed open dump dp's. Good luck man.
Yes, $2500 turbo is way out of my budget at this moment. I'm trying to save for a house. I'm lucky I spent all that I did recently.
I'll give a little background on my car.
2005 SSL GSR
HKS 264/272 cams
stock block/head outside of the cams
3 inch TBE
stock o2 housing, ex manifold
Injen intake and UICP
Half ams knock off/half greddy LICP
Buschur Street FMIC
Walbro 255pump
ACT clutch
With the above mods, I put down 350/340 on 93 octane according to VD. I've trapped 113, but that was with 1 degree less max timing and less into the curve.
I recently installed some FIC 850's and have ordered a Kando short runner exhaust manifold(identical to the MAP short runner manifold) as well as an Invidia o2 housing. the turbo, manifold, and housing will be installed at the same time. Is it a complete and fair comparison to my stock turbo numbers? No. But, it will still be a good comparison. I'll run a fresh pull through VD and give a direct comparison once i'm done tuning the new setup. Unfortunately, I do not have a MAP sensor so boost reference will be me eye balling my gauge.
