Vishnu timeslips
Originally posted by Darryl@Ultimate Racing
Hey great times! What turbocharger are you using?
Darryl
Darryl
Like Brett said, it's running a GT3037. The smaller of our two options. The bigger one is going to be best suited for stroker motors or built 2.0s that can rev higher. The little 'un, on the stock engine, is wonderfully responsive with essentially no lag time between shifts.
Also, I guess you're the man to ask:
How are you getting those high trap speeds? Are you shifting into 5th? Or you are running a higher rev limit? Judging by the 1/8th traps, our car should be able to get into 125-126mph traps if it wasn't rev limited in 4th by the end of the 1/4 mile. It's just smacking away on the limiter for the last second of the run. And I'm not too confident that I an shift to 5th quickly enough without seeing my ET go sour. What's your secret, if you don't mind me asking?
Thanks!
shiv
Originally posted by SzuChenEvo
Great times! Just wondering...what did you do different on that second run that made the E.T. time so much better than the first?
Thanks for the kind words guys,
shiv
We're running the HKS 272's as well as an increased rev limit.
Shiv
We are on 100% stock internals with an exception of some ARP's. Do you have a dyno chart with your latest upgrades? The 3037 is a nice turbocharger, but from the dyno charts that I've seen it looks to be maxing out a little too soon for our liking. Could it be that you're running out of juice on your 3037?
Cheers and thanks for the info....
Shiv
Congrats on the times. That is great. I honestly believe the EVO 8 motor is pretty strong. I think you could rev to 7900rpm without any problems.
You might also want to look into head studs if you don't have them already.
Some 1g guys have been revving the 1st gen 6 bolts to 8800 with stock heads....And your heads are just as good as ours. As for your rod bolts, thats your own game.
For 60 ft's, try to avoid shifting within the 60 ft at the end set aside for it. It just measure how long it takes you to cross the distance and that shift inside there can hurt you. If you can hit 5th before it, do it.
Shiv - you are the only troll low enough to make claims to be the quickest and the fastest while your new timeslips are neither
Congrats on your times - but you show your angry, envious, idoiocy by making any claims to be fastest evo 8 or what ever other junk you are posting on your section of this forum
Further - insulting me and then locking me from replying is just another low class move
Your time is decent - but something that a lot of people could duplicate on a stock turbo - not a bog deal actually
I have not really pushed my car that hard yet as I have been the quickest since June - no need to risk breaking parts on a daily driver to try and beat my won records
Some advice if you want any respect from anyone with a brain - go out and actually BEAT my time - then you can brag
Bragiing BEFORE you beat my time is idiodic
It's amazing how much ammo you supply. So what are you going to say when Vishnu goes out and beats your record???
Last time I checked Al, my car is faster than yours look at the trap speed. I'm a tuner, not a drag racer so I don't think anyone should expect to see any quick times (ET) from me. I'll just settle for the big mph and launch like an old grannie
Cheers,
shiv
Cheers,
shiv
Oh Al,
I don't know why in your sig you have dynoflashed with your 11.505 run. You were not using your stock ecu you were using a standalone.
Unlike you Vishnu uses there products to set records. How about this fastest USDM EVO with out NOS on STOCK ECU.
I have not really pushed my car that hard yet as I have been the quickest since June - no need to risk breaking parts on a daily duplicate on a stock turbo - not a bog deal actually
*******. Where is the class or professionalism in all of this. AL, you are low. And sadly, despite the fact that we all like to think we purchase products for their own merits, DYNOFLASH would sell a hundred times better if Shiv was selling it. You just don't have the class nor the professionalism that should be required from large scale vendors. You need to learn from people like Shiv, Dave Buschur, Darryl, and the other people that don't just trash other people's products.
Suggestion: attack the LOGIC of what people are saying, instead of name calling. Thats the fools way out.
Cheers,
shiv
Cheers,
shiv
I have trap speeds in the 122 and 123 mpg range
I have a 11.50 with nos and a 11.62 without both quicker than your time
Also - Since July - i only have two drag runs on the track - NO NEED to go back till someone BEATS my time - - comming close is NOT beating me
save the excuses for your sales pitches
