P0069 Code
P0069 Code
I've been recently throwing a P0069 code out of the blue and I am not sure what is causing it. I searched and found out that the MAF could be the issue, so I decided to clean it; the CEL stayed off for a few days after I cleaned it and cleared the code and came back on again a few days ago and cleared itself shortly after. Also, the car sometimes (whether the light is on or off) idles like crap for a few seconds/minutes before resuming normal idle.
I'm assuming the next step is to just take it to the dealer, or is there anything else I should try/know about this code? The CEL isn't on currently, so would the dealer be able to see the past codes that were thrown? How much do you guys think a new MAF would run me? Thanks in advance.
Code is for abnormal correlation between map sensor and baro sensor and here are the possible causes
- Manifold Absolute Pressure sensor harness open or shorted to ground
- Manifold Absolute Pressure sensor poor electrical connection
- Faulty Barometric Pressure (BARO) sensor
- Faulty Manifold Absolute Pressure (MAP) sensor
- Faulty Engine Control Module (ECM)
I went to go get food a little while ago and the start up was rough. It was wanting to die initially then just started running normal. No CEL either. I think Im gonna take it in tomorrow morning.
Update for anyone else that may have this issue down the road. Dealer claimed it was the MAP sensor, as curse implied, and changed it. Will post again if the CEL comes back on. (It better not for $400).
OneEyedJack
47
Sep 9, 2010 07:30 AM
