Bad luck with FP turbos
I called FP and they told me to try some things before sending it back in. So I am rerouting the pvc line from the manifold to a catch can and back to the the intake like they told me. Then I am going to make sure the return line is sealed correctly. And for the sake of trying everything I even bought some stop leak oil stuff to help reseal the valves although Im pretty sure its not an issue since I did a compression and leak test before and they came back good.
I just dont understand why this happened on the two fp turbos and not the stock one. We will see Ill keep the thread updated.
^^^ There's your problem.
Read:
http://store.forcedperformance.net/m...otor%20Oil.pdf
Read:
So for the cliffs notes crowd out there, here is the summary: Do not use Mobil1 10w30 or any other “on
highway” GF-4 oil in your 4G63 motor with any FP high output stock appearing turbo. Use a suitable racing oil
designed for high film strength and heavy pressure loading such as Brad Penn, Joe Gibbs, Valvoline VR1, Amsoil
Racing oil or Royal Purple racing oil. Also remember that racing oils are detergent free and need to be changed
frequently.
frequently.
Some blends of Mobil 1 have gone down hill since the GF-4 spec has come out. Not all Mobil 1 oils are bad. I still use Mobil 1 0w-40 in my daily and 15w-50 in my Evo since its not GF-4 and has higher zinc levels. Why would you want to use an oil that can't protect your turbo in your engine??? There's been huge threads on this oil topic and its already been beaten to death.
https://www.evolutionm.net/forums/ev...selection.html
https://www.evolutionm.net/forums/ev...about-oil.html
https://www.evolutionm.net/forums/ev...nal-turbo.html
FP never mentions to run those oils only in Red and Black. They state:
"Do not use Mobil1 10w30 or any other “on highway” GF-4 oil in your 4G63 motor with any FP high output stock appearing turbo."
I would assume this would include the Green. Can someone call FP to verify this?
When you go to the Forced Performance online store the HTA FP Green does not mention anything about the upgraded oil line or the oil list on its product page. The Fp Red and Black both say that an upgraded line and recommended oils are required to retain warranty of the product.
remember guys ZDDP ( Zinc and Phos ) is not only beneficial to FP turbos with similar metal designs but also to your engine, and specially your top end of the engine, cam lobes, lifters, rockers ect... ZDDP is hands down best antiwear additive yet in the market.
DOnt get less than 1000 for your engine or less than 1350 for the FP turbos
well it couldve been oil choice, i know its good for stock turbos but u need some better oil with a bigger turbo. Ive been running valvoline vr1 20w50 so far about 10k, but ive got 30k and counting on my fpred, although im only pump gas all the time maybe that makes a difference?, ran royal purple for a while, **** was nasty, did the mobil1 for a while. i dunno
