Turbo manifold leak??
My car is sounding like a diesel or when you stick your tongue out and blow air. It sounds like the turbo manifold gasket to the head but im not 100% sure, is there a way to pin point the problem. Im afraid to drive it, but on the way home from the neighborhood cruise it was still making boost. Could this be spark plugs? or O2 housing leak? Is it safe to drive? help please! I ordered Turbo manifold to head, to turbo, and O2 housing gasket hoping this is the problem.
if its still making boost properly like before then i highly doubt its any of the gaskets pre turbo. trust me i had a small exhaust leak from a cracked manifold and i couldnt hit full boost until almost redline. it very well could be the 02 housing to turbo or the downpipe gaskets since they are after the turbo. does the sound stay the same throught out the rpms? or does it get louder? what part of TN are you in i could possibly drive over and help you pinpoint the problem if the gaskets do not fix it.
jk_evo8
May 7, 2016 08:44 PM
WarmPepsi
Feb 17, 2016 04:04 AM
kanyonkid
May 19, 2011 07:52 PM
