Does my clutch fork look right?
I noticed that my clutch fork doesn't look like it's centered, also notice with the clutch depressed fully the fork hits the bell housing.
Heres a pic with the clutch not touched:
Thanks
Thanks
Take off the slave cylinder, unlock the TOB and re Lock it.
What could have happened if you just had the trans out is the metal collar clip where TOB locks into is bents or popped off half way. To fix it you need to remove the trans.
Bump.
I'm being told by the shop whom installed the clutch that this is normal?
AFAIK this is not normal, my clutch is drags and disengagement sucks no matter how much the pedal is adjusted.
This is a HD pressure plated sprung ACT 6 puck with streetlite flywheel.
Yes exactly, which is how it sat with the old clutch too. It used to sit center, which is where it's supposed to be. Just hate it when a shop owner thinks your stupid and will listen to what you say.
Thank you. I'm not going to anymore shops, this is the primary reason why I have avoided shops. If I don't know you personally, you won't be touching my car.
This place is a Evo shop too.
No court needed, just a good shoe to the a$$ of a lesson.
ElectricBlueIX
15
Nov 23, 2019 05:08 PM
