Replaced all Injector O rings and still leaking ??
Are you sure you put them in good? I have fic injectors, and they were a pita to put in. Kept popping off of the fuel rail or popping out of the manifold. I ended up pulling everything off that was attached to the fuel rail, and taking off the stress bar to get better access.
1 Post
Did you put the o-rings in dry or did you put a light coating of oil on them before you installed them? Mine were leaking so I replaced them about a month or so ago. I took the cap off one of my qts of oil and put some oil in the cap then dipped the o-ring in it before putting it on the injector and into the intake manifold. I've seen this recommended when installing these a couple times on this site. I would imagine it helps them seal properly. If you put them in dry something may be pitched or they didn't seal properly.
I was look at some pictures and I noticed something about my injectors:
Mines:
http://www.fuelinjectorclinic.com/cg...ey=IS226-2150H
What I have seen:
https://www.evolutionm.net/forums/sa...-ix-plugs.html
http://www.streettunedmotorsports.co..._injectors.htm
they all look different.
Mines:
What I have seen:
i pm the seller of those injectors he never pm me back but the seals he has are a diffrent color then mine and my injectors are brand new mine have a blue seal where his are green but mine fit better in my ams rail with oem seals.
deathtracks
Sep 27, 2010 07:00 AM
