Boost Leak Tester for HTA Green With 84mm cover
wondering what you guys use for boost leak testing with this turbo with the 84mm cover. i am ideally looking to mimick the below but unfortunately pvc does not exist in 2.5 inch diameter which is what i would need to make this work with the fp intake pipe (silicone pipe). looking for ideas or what you guys are using. ideally would like to attach the boost leak tester to the intake fp intake pipe directly as opposed to the turbo inlet
http://www.mellonracing.com/index.ph...4cea066a27ac03
1 Post
How about this...contact them and make sure its for the larger compressor housing...I'm pretty positive it is though since it works with the FP Black...
http://www.turboboostleaktesters.com...dsh-Kit/Detail
well if im not mistaken arent the couplers for the 84mm pipe right about 3" diameter? if thats the case look for a 3" straight coupler, and i believe pvc is also available in a 3" diameter, you just need the end cap.
yes i figured if there was a product in existence that could pressure test from the intake pipe it would be easier especially given that i do not have a heated garage and it gets frigid cold in nh so would be a quick and i dont know how many times i have dropped a socket on to the under tray and had to fish around for it
ok so would you recommend the 3.25 inch size so there is some wiggle room?
http://www.siliconeintakes.com/produ...242ebfe198bca1
here is another one ready to use.
yes 3.25 size
Mellon Racing
Evo 'For Sale' Engine Internals and Drivetrain
443
May 29, 2015 09:40 PM
Mellon Racing
EvoX 'For Sale' Exterior Styling
381
May 29, 2015 12:03 AM
Mellon Racing
Evo 'For Sale' Electronics / Lighting / Audio
381
May 24, 2013 05:54 PM
Mellon Racing
389
May 24, 2013 05:52 PM
Mellon Racing
Evo 'For Sale' Miscellaneous
367
Feb 5, 2013 05:30 PM
