Full Race Exhuast manifold
#91
yeah many new turbos, and a tremendous amount of different housing options. pretty cool stuff!
Originally Posted by Ron
Hey Geoff, can you elaborate on this, do you mean they are coming out with new generation turbos or what?
#92
Originally Posted by Full-Race Geoff
there really is a lot of conflicting data in terms of divided vs undivided housings. Some say they work great on everything some say they work well on diesels and low rpm gas motors. I know that normally i would prefer a 4-1 collector with an undivided turbine housing. On built engines with built cyl heads which can rev, i really feel that most setups would lose enough top end with a divided setup to warrant using an open housing.
Of course, it's very difficult to empiricalize this from behind the comfort of a keyboard (like you said, testing is needed to uncover the nitty gritty details). But one can almost certainly guarantee that as always, you give up something to gain something else.
#93
one more thing to consider is that many of the manifolds on the market do not pair the cylinders properly, but if you look at ours, cyls 1+4 are together and cyls 2+3 are together.
Edit: The Airwerks stuff looks to be promising. Some sort of concoction will be going on a bike soon, hopefully the results are as good as everyone is hoping for.
#94
in a 4-1 why is pairing important?
and can you elaborate on how a long tube is more succeptible to reversion than a short tube...
#95
I'm of the same opinion as Shearer and Trinydex, in that if every primary runner is absolutely equal, I don't see where pairing is relevant.
As for reversion, it occurs only at lower engine speeds when a large exhaust system and long overlap cam set is used, and is essentially a non-issue here. Why? Because even cams such as the HKS 272 set deliver only 214 deg duration at 1mm and give very decent low speed characteristics. For the sake of discussion however, a collector is in effect an anti-reversionary device. Once exhaust pulse exits into a larger area (collector) and expands, the slight negative pressure of reversion is insufficient to allow it to suddenly reform and be sucked back into the cylinder. Just have a look at going back through the exit of a collector and one can see the return path is virtually impossible in an aerodynamic sense. This being said, the shorter the distance between the exhaust port and the collector (essentially the lower the primary runner volume), the lesser the volume of intact exhaust pulse than can be sucked back into the cylinder. This is why tubular manifolds that employ anti-reversion cones position them immediately after the exhaust port exit.
#96
hmm... i see what you're saying... but in the case of a long tube runner isn't it also true that there is usually a following pulse that can't/won't get sucked back after it enters the collector simply because of the fact that there is another pulse coming out where in a sufficiently short runner (say the stock cast mani if there was no twin scroll) a pulse can actually get pushed into another runner for lack of collector and because there's no followup pulse "cleaning out" the runner?
and i don't know if this would be more pronounced in pulse timed headers or equal length. but in equal length when you hit the collector you have the power of two pulses to push gas back up other tubes, whereas in pulse timed headers you always get a scavenging effect, but i suppose that's most pronounced after the turbo tho....
so another question, why aren't pulse timed headers more popular and powerful especially for turbo applications? or are they and all this el stuff is just hype.
i would say equal length is good in the sense that it doens't vary back pressure across the motor's different cylinders... that is one good thing.
#97
#99
#100
Originally Posted by meanmud
are ya going to let us know how the kit is?
#101
this is gonna be a long one!
sorry for the confusion. To be honest there really is no clear answer on how the pairing of cylinders affects flows in a 4-1 system. Some engineers agree with you, others strongly disagree. What i have noticed is from one particularly noteworthy header designer from the west coast stresses the importance of proper cyl pairing on 4-2-1 and 4-1 setups. He feels that the proper cyl pairing creates a stale boundary layer between the cylinders sort of like those thermal air barriers at supermarkets which keep the heat in (for lack of a better example right now)
There are 2 points i guess i should mention
1) the cylinder pairing is such that if you wanted to run a divided housing, all you/we would have to do is seperate cyls 1+4 and 2+3, not have to completely redesign the manifold or be stuck pairing the wrong cyls together
2) the best book i have made a number of points in one of the early chapters regarding turbocharging manifold design, so i figured ill just copy them verbatim with my comments in parenthesis
- it is difficult to obtain even steady state characteristics over the full potential operating range of the turbine under representative conditions
- partial admission turbines (basically anything with a wastegate) add the further complexity of unbalanced mass flows even under steady state conditions
- the turbocharger turbine never operates under steady flow conditions, even in the so-called constant pressure system (something like a generator that operates at a constant boost and rpm level) and the effects of unsteady flow should be considered (can be calculated by a quasi-steady technique in which the size of the turbocharger is defined by its steady state characteristics, and the measurements are taken at the inlet flange)
- the effect of out-of-phase pulsating flows in partial admission turbines is not fully understood (*** this is the one which applies most ***) However, good general practice is to pair cylinders according to the engine's respective firing order, keeping flows in-phase.
With regards to the long tube being more susceptible to reversion than a short tube, i strongly disagree. I really dont follow how you came to that conclusion? It really goes against traditional exhaust theory.
i strongly disagree that reversion only occurs at lower engine speeds. I do agree that a true merge collector is also a bit of an anti-reversion device.
last note, equal length means nothing. The defining point is equal pressure. Putting a measuring tape inside of a 180 degree bend and reading the length will only tell you the circumference, not the actual friction and pressure drop, which are what really matter.
Originally Posted by Shearer
If the collector is symetrical across both axis and runner length is equal across the board it does not matter which hole the runner goes to. If this was a divided set-up you'd be dead right, but all four runners are merging together negating any effect of cylinder pairing.
Originally Posted by Ted B
reversion occurs only at lower engine speeds ... and is essentially a non-issue here. a collector is in effect an anti-reversionary device.
#102
Pulse tuning is basically what you call *any* manifold used in a turbo app whereby all the primary runners collect at the turbo housing inlet. Such a manifold may or may not have equal length runners. Equal length runners are desirable because they evenly space the exhaust pulses.
#103
I agree with you that the term 'equal length' can be misleading, especially in an application (e.g. EVO) where bends are necessary due to spatial constraints, as disparity between them can certainly affect pulse timing.
The 'thermal barrier' concept is a novel one. A 4-2-1 manifold will certainly benefit from cylinder pairing, but as for 4-1... ???
#104
#105
The possibility for reversion to be significant at higher engine speeds is possible in suspect applications, being far more likely to occur in a heavily cammed N.A. engine with drag pipes as opposed to the typical EVO given the most popular cam sets and its turbo size.
