home brew Oil supply line for turbo?
Old Aug 24, 2011, 06:40 AM
n2oiroc's Avatar
Not ideal, but you could just run a bspt die down an npt fitting. Its the same thread but with a 5 degree pitch difference.
Old Aug 24, 2011, 11:29 AM
gear head's Avatar
Check your local hose shop...the shops we have around here carry BSPT X JIC fittings.
Old Aug 24, 2011, 11:44 AM
kornkuu's Avatar
try this page down at the bottom.
http://www.mcmaster.com/#catalog/117/28/=drf2p8
Old Aug 24, 2011, 01:07 PM
211Ratsbud's Avatar
Whats jic? afaik I need 3/8 bspt to an -4
Old Aug 24, 2011, 01:08 PM
211Ratsbud's Avatar
My town sucks nobody will help
Old Aug 24, 2011, 01:34 PM
211Ratsbud's Avatar
I have a jic to bspt on the way will see how everything fits asap. As far a it sounds jic equivalent to an
Old Aug 24, 2011, 01:43 PM
211Ratsbud's Avatar
http://en.wikipedia.org/wiki/AN_thread
http://en.wikipedia.org/wiki/JIC_fitting
"JIC fittings are dimensionally identical to AN (Army-Navy) fittings, but are produced to less exacting tolerances and are generally less costly. 45-degree flare fittings are similar in appearance, but are not interchangeable."
quoted from wikipedia
Old Aug 25, 2011, 01:33 PM
211Ratsbud's Avatar
all oil line parts are on their way minus the filter
which will be shortly
Old Aug 25, 2011, 02:14 PM
Spec-Ops1's Avatar
I got the oil filter housing fitting from 42 draft designs and just got an NPT to -4an fitting from jegs...
http://store.42draftdesigns.com/Lanc...ptor_p_54.html
http://www.jegs.com/i/Earl%26%23039%...81604/10002/-1
Old Aug 25, 2011, 04:06 PM
211Ratsbud's Avatar
I bought 4 of bspt x jic from a warehouse for 6 $ ea. Trying to use real fittings instead of adapter adapter, however great solution because its a tough fitting to buy solo lol
Old Aug 25, 2011, 04:09 PM
211Ratsbud's Avatar
24 + 60 an fittings and hoses, + filter 30
Old Aug 26, 2011, 12:36 PM
211Ratsbud's Avatar
i purchased the fittings and lines from AN fittings direct. They are here today, bspt-jic will be here soon i hope. filter will come from stm.
Old Aug 27, 2011, 02:22 PM
1UpMoto's Avatar
I would think this line would work with our cars if its long enough.
http://www.extremepsi.com/store/prod...cat=336&page=1
Old Aug 27, 2011, 02:29 PM
211Ratsbud's Avatar
...mmm i think it would but at the same time I wanted an inline filter to boot.
Old Aug 27, 2011, 02:36 PM
sparky's Avatar
Originally Posted by 1UpMoto
I would think this line would work with our cars if its long enough.http://www.extremepsi.com/store/prod...cat=336&page=1
That looks like a good find, 1UpMoto. This line apparently serves the same purpose as the FP oil feed line, only sans the inline filter. It should be strictly plug and play, huh on any 16G? So, it ought work on my second hand, El Cheapo Red.
Quick Reply: home brew Oil supply line for turbo?
