What the heck is high rpm lockout?
The reason I ask is because I dont know what kind of clutch I have in by car but when I bought it it had a wally 255 and a bunch of aftermarket stickers in the trunk. When my first tuner started the car he said that he thinks it had a three disc clutch in it but I cannot confirm or deny this. I just got my car tuned again this weekend and my clutch started to slip on one of my pulls but isnt slipping now, but I am having a hell of a time shifting my car into 2nd or 3rd now. I have the clutch in all the way and miss each gear 2-3 times when trying to shift.
Could this be because of the slippage maybe the tranny isnt disengaging all the way or is high rpm lockout meaning you cannot shift at high rpms? I think I may have bent something in the shift area as well because the shifter is almost touching the top of the opening when it is in neautral. And when I go 1st 3rd or 5th it almost touches the plastic ring. Any help or input is greatly appreciated, thank you.
I would look under the hood and see if your bushings are shot. If so, get some solid bushings to replace those rubber OEM ones. They feel a lot more accurate and it'll help you with shifting.
But high RPM lockout is when you're high in the RPM, depress the clutch and it just won't let you in the gear you want.
Ok I will check my bushing. I cannot get into 2nd or 3rd to save my life, it literally takes a few attempt at getting it into gear. When I am driving normal it feels fine but anything over 6k it just wont go into gear. I wonder if thats what I am experiencing then.
Well it never used to do this until my last tune and the clutch starting the slip that one pass I made. I will see if adjusting the pedal helps. Im guessing either my clutch is locking out or its just shot and wont disengage properly at full throttle operation.
It sounds like an organic disc. When they glaze over (heat up) they slip. As soon as the glaze is burned off, it starts to grab again. At what point in travel is your clutch starting to engage? A properly adjusted pedal would start engaging the clutch at above the halfway push point.
ps. if in fact you have an organic disc, you more than likely have a single disc clutch. Shine a flash light into the clutch fork hole and see what color your pressure plate is.
I wasnt sure if there was any way to check into the bellhousing without actually pulling it. I will check and see what clutch is in it. It engages about 1/2" off the floor board.
Sounds like the clutch and everything needs some serious help.
CeliOnce
Feb 15, 2017 04:56 PM
tehSteve
Jul 5, 2011 08:51 PM
Turbo Kyle
Apr 27, 2008 10:33 AM
