no fluid in acd pump reservoir
So im buying this evo 9 and i looked at the acd pump reservoir because all 3 tarmac, gravel, and snow lights were on. There wasn't any fluid in it at all. If I add fluid to it will it damage anything. Or could it be locked up from not having any fluid for so long?
If there's no fluid, then the pump is most likely shot! The whole ACD system could be broken. There's nothing cheap about ACD either. You could add fluid and bleed the system and see if they go way. Is the T-case whining when your drive slow in 1st gear?
You may want to reconsider buying the car until you find out what is wrong, ACD can be quite expensive to repair. Also, I wouldn't drive it around like it is, don't want to cause further damage.
EnjoyDriving
Dec 28, 2015 12:48 PM
silentsniper605
15
Oct 14, 2015 05:33 AM
