oil pan leaks
Old Jan 2, 2004 | 03:19 PM
nostim's Avatar
Question oil pan leaks
I went under my car today to change the oil and noticed oil dripping from the drain plug on the oil pan. I searched around and seemed to have located the source, it appears it is coming from the oil pan area closest to the flywheel. Has anyone had this problem? I also had a a few drips on my garage floor. BTW my EVO only has 1000 mi.
Old Jan 2, 2004 | 03:24 PM
dpwurzer's Avatar
i noticed a small leak when my car had 500 miles on it, i changed the oil @ 1200 and the leak is gone, sometimes the seals have to set up, but it should stop leaking.
Old Jan 2, 2004 | 03:29 PM
nostim's Avatar
Yeah, I went ahaed and changed the oil, I guess I will check every now and then to see if it has stopped. Anyone else???
Old Feb 19, 2004 | 09:14 AM
EJEvo's Avatar
Oil leak from pan
I noticed about a dozen quarter sized drops on my garage floor yesterday afternoon. Took it into the dealer this morning, and they said the oil pan is leaking from what they believe is the gasket seal. They'll need to order special gasket sealer and then perform the repair. I've got about 900 miles on the Evo.
Whatever happened to using a pre-cut gasket?
Old Feb 19, 2004 | 09:38 AM
nostim's Avatar
I ended up taking mine into the dealer. They confirmed the leak and reapired it. No more leaks. Sounds like your service guys are doing the same thing to yours as mine. Good luck!
Old Feb 19, 2004 | 10:35 AM
evil8's Avatar
Any of you guys had the leak come from the oil return line? That's where mine was and the dealer fixed it.
Old Feb 19, 2004 | 11:11 AM
nostim's Avatar
No, my leak was just from the back left corner of the oil pan. A leak from the return line had to be messy!
Old Feb 19, 2004 | 02:49 PM
bluevilevo8's Avatar
Mine's leakin a few drops from somewhere. I'll mention it next time I'm at the dealer.
06RedRalli
Nov 24, 2015 08:02 PM
Svendiesel
Nov 29, 2013 10:30 AM
user 629782012
Nov 24, 2012 11:31 PM
chuysralliart
Aug 11, 2011 09:43 AM
05 MR
Mar 9, 2006 09:25 AM
Quick Reply: oil pan leaks
