Sloppy Driveline/Jerking and Bouncing
Every gear in the transmission, transfer case or rear differential must have some clearance or play. Every splined shaft in the drive train has play. Every constant velocity joint must have some small amount of clearance. Add them all up and the answer is yes.
how many miles on the car? have you looked under it, just for the most part a visual inspection could see if anythin rubber is worn on your car, that would be a good place to start... visual and clean ur tb? see if it cures if not you got a good idea by then what to replace....Good luck
I have exactly the same issue. Changing Diff and moustache bar bushings to ralliart didn't help (possibly made it more noticable). Could it be the sprung plate in the clutch?
Would love to find the answer. This really cheapens the ride quality of the car.
Interestingly I had a similar issue with an evo 7 and changing the diff and moustache bushing fixed it 100%.
I have this same issue.. but it only started after i got a fully built Tcase from MAP. It could have been the installation or the tcase build itself, but it's definitely noticeable and jerks the whole car when i let off the gas on the street or the highway.
I too have tons of backlash in the drivetrain, especially when 'givin her. Even over a real bad road at constant speed the bumps will bounce the driver around enough to stutter the throttle and get the driveline into this occilation that leads one to just completely lift or punch it.. I was guessing the motor mounts need to be replaced, but now not sure if it's the four around the rear diff or other bushings to be replaced as well.
I really don't want to end up with a nasty buzz-box due to overly stiff bush's. Looking for any suggestions.
Oh, and in my case it isn't a sticky throttle, nor does it seem to be the drivetrain itself (newish clutch, and tight trans, etc).
sorry to revive the thread guys but i have the same problem and would like to fix it ? did any of you guys come up with anything that helped?
im close to getting some rear diff + mustache bar bushings but the only thing stopping me is horror stories of obnoxiously loud whines at 60-80mph !
i also have a front MM
I recently installed the Energy Suspension red bushings on the rear diff and the AMS black front MM bushing. Still have quite a bit of slop in the drivetrain, tempted to do the driveshaft bushings next. Even had the throttle body cleaned, throttle cable adjusted, and new clutch. Trying not to over do it and generate too many vibes in the cabin.
wow, even with the rear diff bushings it didnt help? do you have mustache bushings too? and has your car gotten a louder whine noise ? ?
hmm the bushings didnt fix the slope maybe i might hold off on them ...
