Thrust Bearing Failure
Ok SO after having the car built with about 10k miles how would a thrust bearing fail what would cause this ?? Also the oil squirters fell to the bottom of the oil pan they got knocked off maybe by the thrust bearing but what would cause this anyone?
Ok well could anyone explain to me I looked for what oil squirters do and it says it feed oil to the bottom of the pistons? THe reason i ask is because the way I found out about the bottom end I had a tap from the head so all the lifters got loud. So I just thought they needed replaceing but come to find out I had no Oil pressure to the head, so then I was gonna replace the oil pump because I thought that was the problem. Then i saw it was the oil squirters but do they feed oil to the head also? Or it may also be the oil pump??
I take it you have the 6 bolt block. Did the squirters including the banjo bolt that holds them in fall out or just the squirter tubes? If its the tubes only then they probably got knocked off by excessive crank end play. Did the thrust bearing burn up on the clutch side or pulley side?
Since you have a dsm have you tried dsmtuners? There is a ton of information on there about the dsm.
