TB Shaft Seals and low TPS readings...
I did the TB shaft seals a bit ago and have been logging TPS through Evoscan and at idle its 14.5 which is a little high but still within reason, but Im only seeing 32.5 at WOT. Did I install something wrong? Thanks
I did read the how to, its the only reason I was confident enough to do it. I used a "not-so" permanent marker and between that and my greasy mits the lines were a little hard to see. BLK EVIL my sockets wouldnt go on it, Ima try to find one with thinner walls I suppose
