Evo bov question
Old Sep 20, 2011, 03:16 PM
cruzincarl's Avatar
Evo bov question
I put a manual boost controller on my evo 8 its a 2003 and check engine light came on and it said it turbo over boost when had it checked so i took controller off, but now my bov dont purge like it use to, it use to be kinda loud and now nothing, any ideas?
Old Sep 20, 2011, 03:21 PM
Raptord's Avatar
Pics of the engine bay would help, possibly a vacuum line you didn't hook back up properly?
Old Sep 20, 2011, 03:38 PM
pacent's Avatar
What does your boost gauge say? If no boost gauge, why did you bother trying to hook up a MBC?
Old Sep 20, 2011, 03:40 PM
brenner's Avatar
sounds like you hooked it up wrong
Old Sep 20, 2011, 04:08 PM
Drift to Grip's Avatar
+1 for pics
Old Sep 20, 2011, 08:03 PM
sparky's Avatar
Originally Posted by cruzincarl
I put a manual boost controller on my evo 8....check engine light came on and it....over boost..... so i took controller off... now my bov dont purge like it use to....
What BOV are you using on your Evo?
Old Sep 20, 2011, 09:32 PM
novem's Avatar
Put the MBC on, and leave the stock controller plugged in. Just put the small hose on the ends of the stock controller or cap them off and you should be good.
N
Old Sep 20, 2011, 09:38 PM
sparky's Avatar
Originally Posted by novem
Put the MBC on, and leave the stock controller plugged in. Just put the small hose on the ends of the stock controller or cap them off....
There is no stock boost controller on our Evos. You must be refering to the factory boost control solenoid aka BCS.
Old Sep 20, 2011, 09:54 PM
novem's Avatar
Yes, the stock boost controller..just leave it plugged in and cap or put the small hose on.
N
Old Sep 21, 2011, 11:42 AM
cruzincarl's Avatar
Bov
I know how to read and directions and hook it up and yes i had a gauge, gauge read negative 24 at idle. That normal?
Now on bov, I hooked it back up like it was, two lines of bcs then one runs to air intake and other down to a T by wastegate then one to wg then other is pos line to turbo. then bov is hooked like it always was.
Old Sep 21, 2011, 12:32 PM
cruzincarl's Avatar
Bov
Is it possible that the bov just sucks and would stop making the noise just cuz?
Old Sep 21, 2011, 01:50 PM
pacent's Avatar
How much boost are you pushing under load hooked up to the stock BCS?
Old Sep 23, 2011, 12:42 PM
cruzincarl's Avatar
I am not sure what you mean. at idle boost reads negative 24 or so, and bov is hooked up right so is it possible its just not making the sound anymore because its just not?
Old Sep 23, 2011, 12:58 PM
Raptord's Avatar
How much boost are you seeing at full throttle? That's what he wanted to know
Old Sep 23, 2011, 12:59 PM
wazzelby's Avatar
What we're trying to find out is how much boost you are getting when you get on it? What is your full boost reading at wide open throttle?
