only boosting 12 psi?? help me out please..
okay so i just bought an 05' evo 8 MR the boost gauge wasnt working. i replaced the vaccum line runnung to the intake manifold and the gauge reads 12psi of boost on a 4 gear pull.. stock boost is supposed to be 15-16psi spikes 19.. why is mine so low? could it possibly be from a tune?
other possibilities include wga, exhaust leak before the turbo, boost controller or stock solenoid, and vacuum lines. check all of those, and the turbo for shaft play and you should find the problem. also if the car is stock from where the previous owner returned it to stock more than likely they didnt put the "boost pill" back in. search boost pill and you can find numerous threads about it and where it goes. thats more than likely the problem.
EvoDan2004
28
Oct 25, 2013 08:58 PM
