Car stalled won't run
Old Oct 18, 2011, 01:03 PM
Evofletch's Avatar
Originally Posted by PaEvo
you mentioned the crank sensor. that got me to thinking. the last time my evo was on the dyno, the tuner dialed in a base map, and shut the car off to go outside and smoke a cig. when he hopped back in, the car wouldn't turn over. the tuner and a tech took a quick look under the hood and after a minute noticed that my TPS (throttle position sensor) had worked itself out. two minutes and a foot of all purpose wire kept the sensor in place. tuner turned the key, and car fired right up.
So, you might be on the right path by thinking its a bad sensor or loose connection. all it takes is one thing to come loose and you're not getting far.
I havnt had anymore time to look at it I just hope it's not my crank sensor cause i really don't wanna tare the timming **** off lol it sucks but gonna check the easy stuff first
Old Oct 18, 2011, 01:06 PM
Evofletch's Avatar
The other thing that makes me like wonder is why is the fuel pump not kicking on
Old Oct 18, 2011, 01:21 PM
bigboybusa's Avatar
That has happened to me on the track. The crank sensor went out on straight way, luckly i coasted into the pits. When we checked it out, it would crank but woulnt turn over, we pulled the fuel line and no pressure. We changed the pump there and still nothing, so we got it back to the shop ran diagnostics and there was no signal from crank sensor.
Also another time it was my idle control valve, located right underneath the throttle body.
Good luck!
Old Oct 18, 2011, 10:32 PM
Evofletch's Avatar
Took care of it car runs thank you guys
Old Oct 19, 2011, 01:43 AM
triple L's Avatar
so how did you fix the issue!? good thing u fixed it
Old Oct 19, 2011, 09:08 AM
Evofletch's Avatar
It was a wire by my kick panel and once I pulled it off the wire hit the body of the car and made it pop a fuse
Old Oct 21, 2011, 12:05 AM
PaEvo's Avatar
Lol. Not blaming you, but I'm tickled by this conclusion. Well, at any rate I don't fell dumb/feel like I do have some idea of what I'm talking!
In the end, it was electrical, an a fuse issue. Again not callin op out, but how many of us pointed him in that direction?
Glad the prob was resolved, and didn't cost too much!!
khay silk
Dec 5, 2015 11:21 PM
khay silk
Oct 8, 2015 05:00 PM
ArchieBabes
Feb 23, 2006 08:42 AM
arpad
19
May 23, 2004 12:46 AM
johnjonfenomeno
53
Aug 8, 2003 06:16 PM
Quick Reply: Car stalled won't run
