Can someone label gears in transmission
I attached 2 pics, out of the two pics can someone open up paint and label which gear is what.(1st,2nd,3rd, ect.)
Thanks
Thanks
starting at bottom. with small gear on left mated to largest gear on right. that is first gear. the one above that is second. the one above that is third. and hopefully you can figure out the rest from that.
scary thing is if you have to ask this question you should positively NOT be working on your own tranny.
