Exhaust Camshaft position sensing cylinder \ Exhaust cam angle sensor
Love you! Totally in a gay way
Damn you, I had this question when I was putting my motor back together and not one person answered....so I just put it together and she's been running so I guess it was the right way ...I did get a cam synchronizer? code for the sensor but once I cleared it, it never came back. Either I was lucky to do it right the first time or it relearned it and adjusted to it?
Just set you engine to TDC then unscrew the 3 10mm bolts and check to see if that piece is in the correct position. Take you like 15 min total. Including pulling your spark plugs so you can crank the engine.
It will run in either position the same from what I've seen. Many times trying to fix local heaps hoping this was a problem and switching it to the correct position( found two wrong so far) the cars ran exactly the same after, does not throw a code in the wrong position either.
Wow, that's good to know! I pray my car starts up with no issues after this major build I'm doing it all by the book, hoping to make some good power out of it. Now I just need a big T on the cheap
FS[West]: OEM EVO 9 Exhaust Manifold
fugiwara
Jun 9, 2016 11:29 PM
RedEvoxGSR
Oct 22, 2013 08:17 AM
