any one daily drive a Quartermaster twin
Old Oct 27, 2011, 05:43 AM
B.J.@ToxicFab's Avatar
Originally Posted by Creamo3
I'm running the newer 8-Leg QM Race and love it for holding power and high RPM shifts. I don't daily drive it though and if I were going to I would go with the street version with the heavier flywheel.
Does anyone run a clutch pedal stop? Doesn't appear to be anything aftermarket and I might just make one.
From what I have read the floor clutch pedal stop is definitely recommended. IndyEvo/9sec9 have a clutch pedal stop on their website, check it out...
Old Oct 27, 2011, 05:50 AM
Creamo3's Avatar
That website has been dead for a while now www.9sec9.com
Old Oct 27, 2011, 06:09 AM
bostonhatcher's Avatar
I welded a coupling nut to the firewall and then threaded a bolt into it and covered the bolt head in rubber tool dip so you don't get the metal on metal noise when the clutch pedal hits it. My clutch is also adjusted all the way down so my total clutch travel is about 3-4 inches. I wanted to utilize the stop because it makes the engagement more predictable and to minimize wear on the thrust bearing.
Old Oct 27, 2011, 06:51 AM
psphinx81's Avatar
i run the tilton pedal stop, however they rape the **** out of you.. its like 30 bucks lol
Old Oct 27, 2011, 06:57 AM
Ahhh, forgot about that...They are still active on the Midwest Evos Forum...not sure if you are on there or not...
Old Oct 27, 2011, 06:59 AM
THUB's Avatar
The factory plastic pedal stop has an actual thread in it, though I can't remember what size. I just garbbed a bolt and a nut to jam it in position. cost me like 60 cents.
Old Nov 3, 2011, 10:52 AM
Creamo3's Avatar
That's similar to what I did, I took the pedal stop off and jammed a washer-nut into the backside so that I could adjust the height on the bolt. I also put a small piece of silicone hose on the bolt coming off the firewall to keep things snug.Cost me nothing
VR4Babe13
Jun 27, 2016 09:27 AM
bsh
15
Feb 10, 2011 12:44 PM
dambikeracer
Dec 29, 2010 07:53 AM
EvoIIIAj
38
Aug 19, 2010 10:30 AM
fid
23
Apr 21, 2009 04:10 AM
Quick Reply: any one daily drive a Quartermaster twin
