Help me get more power out of FP black buschur setup ;)
I'd say JMFab O2 dump would be the easiest HP for the $. Then the V5 and S3's also if you are looking to upgrade everything. If you dont want the dump then Id def say do the S3's and then the V5 = Enjoy!
Here you go.
https://www.evolutionm.net/forums/ev...p-results.html
Also forgot to mention go SD if you havent either bnr34rb26dett!
Ill tell you from personal experience that I had a +50 HP increase in top end (not overall) with my black when I went from an invidia o2 housing to an EPM dump Boost held a lot better up top with my dump
E85 if you were able to get it.
Bigger FMIC, Buschur Race of BFMIC
Fuel - Double Pumper and bigger injectors
SD
DI Intake Manifold (if you can get one)
Solid Setup already. Enjoy it!
SD
your setup is excellent, but 2 changes to see huge gains. Get the magnus v5 because it has a much larger area for the flow and will make substantial gains, along with a more aggressive cam. FP, GSC, try them for more gains
02 dumps sound like crap and it's not all that. The perrin air filter has shown the most gains, you might pick up a few whp there. And a retune
magnus v5, cams, tune, maybe filter swap also
