Going for the drop-in build at English Racing
I'll start by saying that my engine performance goals are a 4000-7500 rpm powerband with no more than 550 ft-lbs of torque and 600 whp. I really like having a fast car, but my budget just won't allow an all out engine build. After talking with Aaron a bunch (probably to the point of annoyance) and reading around on the forums, I could find no reason not to go with a drop-in build. So, its underway.
A few highlights of the build parameters are:
- New style JE asymmetric skirt pistons in factory bore size. I have to wait a month to get these. Ugh. The motor has already been torn down and cylinders honed. Aaron said the piston-to-wall clearance is going to be about 0.0045".
- R&R steel rods. Lucas said the clearance on the rod bearings will likely be about 0.0016"-0.002".
- Keeping the balance shafts.
- Keeping the piston oil squirters.
- Kiggly HLA.
- Buschur modified oil pan.
- Cosworth crank scraper (via Buschur).
- ARP head studs and main bolts.
Power mods being done at the same time:
- English Racing port job on the head.
- MAP O2 eliminator with merge.
- MAP Rev3 intake manifold.
- Muffled test pipe.
For near term, I'll be staying with:
- BBK Full.
- MAP short runner exhaust manifold.
- HKS 272/278 cams (new version).
- ETS 3.5" intercooler.
- Factory MAF-based air metering.
My goal is to set the BBK Full E85-powered torque and whp record. Not sure my stock clutch will hold it, but I'm gonna give it a try. :-) Many thanks to English Racing for being patient with me on this. I've been bugging Aaron about this for almost a year.
- Kiggly HLA.
- BBK Full.
I'm glad you started this thread. I feel as if I am on the same page as you!
My power goals are the same and of course I have a limiting budget where an all out built is out of the question.
Approximation: how much do you think this project of yours will cost?
Labor cost?
Parts cost?
Labor cost?
Parts cost?
Labor cost?
Parts cost?
Labor cost?
Parts cost?
