bent FMIC fins
bent FMIC fins
How bad is it to have alot of bent FMIC fins.
My AMS FMIC is starting to get have quite a few bent fins
I tried bending it straight but some are just unfixable.
Will it affect performance by alot with alot of bent fins?
as long as there are no punctures / leaks in the FMIC system its ok.. but you could go through the fins and straighten each one out carefully with a razorblade or similar.
as long as not a whole lot are bent you are fine. dont worry.
They sell combs or teeth rakes that come in different numbers of teeth per inch, but you can also make your own by sanding down a popsicle stick or the end of a plastic knife from Wendys to fit the normal undamaged size of the spaces. You can make it look nearly perfect if you make the right size tool and take your time
As for straightening bent fins, I use a pair of thin tweezers that fit perfect between the fins. I wouldn't worry about a few broken or bent fins, this shouldn't dramatically affect performance.
FS[Northeast]: Mishimoto Radiator
ineedboostman
Feb 1, 2017 05:24 PM
WTB[SouthEast]: Looking for a used slim radiator Evo 4-6
Howulikemyevo
Apr 29, 2016 07:28 AM
FS[Pacific NW]: Arc fmic
Xchild4584123
Feb 16, 2016 10:09 AM
FS[MidWest]: OEM Evo X FMIC and Front Crash Beam
03chi-town0Z
Oct 9, 2015 10:27 PM
TwistedEvo8
Northeast Region
Jul 31, 2008 06:42 PM
