ef3 vs new fp red bb
#31
Incorrect, we've made 610+whp with an EF3 we just don't recommend running them at that level ![Wink](https://www.evolutionm.net/forums/images/smilies/wink.gif)
We've already discussed my opinion on this and the limited sample set for their "new" technology. Curt and ER seem to be having good luck thus far, no doubt there. However, let's say one of them had a failure, do you think it would be made public?
Define built.
Anyone that has worked with us in the past knows the kind of customer service we offer, these new turbochargers won't be any different
Define built.
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
#33
BB red will not make 650 whp. I am sure it will make better #s with stroker motors or 2.4 motors but its only rated at 550. The ef3 will make 500 easily and on a stroker motor will make more as the red will. Another thing you misrepresent is no the ef3 doesn't have smaller compressor housings. They use the standard mitsu housing unless you want the surge port on it. If your gonna give out helpfull info please get everything correct before you post.
#35
BB Red can make 650whp in the hands of a blind goat. Thus far the durability of both the BB Black and Green have been amazing, this is from a guy that breaks a journal bearing turbo in less than 1000 miles every time. If I were recommending a stock frame bolt on to anyone it would be the Red.
#40
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Are you disputing that at that power level a ball bearing red wouldn't provide for a more durable, longer lasting turbo?
#41
I think what he means is, they wanted a turbo that will be in the x amount of hp range. I mean eveyone knows turbos are rated at x amount of power. I am sure if they squeezed every ounce of power they could out of the turbo and made 610 whp, that they have to dial back the power rateing for warrenty issues. I mean if you go all ***** out on your turbo and it kills the turbo and you send it in for warrenty work, not only is that gonna void warrenty, but they aren't gonna fix it because your out of the power range they wanted you to run it at. I am sure FP is the same way. But I am sure they have deals with the big boys who push them to absolute can't make any more power and they get them fixed for free. Don't let that fool you.
#42
I guess I just understand the limitation of the stock center housing first hand. I'm sure the EF line up are great turbos, but a huge difference in the price (which seems to be a big problem in some people's mind) is due to the BB center section. Hard to dispute that the BB CHRA isn't better than a journal bearing.
#43
I am not saying that in the least being I have both types of turbos on my cars. But I do think it goes back to warrenty issues. Being the bb chra is way more expensive to get and repair to a journal bearing turbo. I think alot of what is being said has to do with that fact. I am sure if the ef3 was designed to compete with a bb red, then it too would have been a bb turbo. At the time the turbo was developed I am sure it was a direct competitor of the journal bearing red. Chris correct me if I am wrong here.
#44
All I'm saying is that you guys have to realize that this isn't Garrett or PTE ball bearing CHRA's which have been proven time and time again. FP themselves touts this as "new" technology and thus far everyone is basing their opinion on results from two of FP's biggest brand advocates that in all likelihood received these turbochargers for free...
#45
I will agree and say that I do not know exactly what FP is using in their CHRA's and that we should not just assume that just because it is ball bearing that it is on the same level of the Garrett CHRA's. You make a good point there Chris.
I have to ask though, you guys must be working on a ball bearing solution, no?
