Please help. Car is broke and need ideas to get it moving so I'm not stuck...
Old Nov 13, 2011, 01:45 AM
tscompusa's Avatar
Originally Posted by cfdfireman1
open the bleeder then start it in gear, drive home it will take some attention and you'll have to look far ahead but it can be done. when you have to stop pop it into neutral turn the car off and start it with the car in first gear again. clutch will be useless but you can drive it. hope you know how to rev match for the downshifting.
reason you'll have to crack the bleeder is so you can get the clutch pedal down so the starter will engage, you won't lose brakes because there is a chamber for the clutch off to the side in the brake reservoir.
theres a plug under the pedal that when you unplug it you can start the car without the clutch pedal. im surprised you didnt know that.. its been there even on the dsm's.
Old Nov 13, 2011, 01:56 AM
WickedIXMR's Avatar
Buy AAA. I'm surprised more people don't have AAA especially if you drive an Evo.. Tsk tsk tsk.. Buy the premium plan and you get 1 FREE 200 mile tow and 2 FREE 100 mile tows per year. Not to mention all the discounts you get and free gas if you run out.
Old Nov 13, 2011, 03:30 AM
therunningskier's Avatar
Opening the bleeder valve did not let me move the clutch pedal...
Old Nov 13, 2011, 03:32 AM
And at this point I think I've given up on trying to limp the car home, too far and too many stoplights. Now more on what is actually wrong with her...
Old Nov 13, 2011, 05:59 AM
Liqquid's Avatar
I've popped the wedge collar off mine before and the clutch pedal can be moved with no problem.. if you take the slave cylinder off the transmission the pedal should go to the floor, and put it back on it won't move? New one on me, but sounds like hopefully damage is limited to the clutch and throw out bearing area
Old Nov 13, 2011, 06:42 AM
cfdfireman1's Avatar
if that's the case then
do what tscompusa said and pull the plug by the clutch. sound like your clutch master took a dump.
Old Nov 13, 2011, 11:39 AM
Today i looked into the inspection hole thingy on the bottom of the transmission housing. A chunk of metal fell out and upon further inspection the throw out bearing appears to wobble and barely stays in there... That cant be good...
Old Nov 13, 2011, 11:40 AM
Will post picture later
Old Nov 13, 2011, 02:40 PM
[IMG][/IMG]
Old Nov 13, 2011, 03:18 PM
My03evo's Avatar
You need a clutch...ACT clutches are KNOWN for the springs and stuff falling apart in the disks....and the high rpm lockout.
Old Nov 13, 2011, 03:20 PM
javicracer's Avatar
U can take the switch off for the clutch pedal!!!! If u know how u can shift without the clutch?!?!?
Old Nov 13, 2011, 03:28 PM
No worries now about getting home. Car got towed.... and is sadly sitting at home in her garage.
Old Nov 14, 2011, 03:26 AM
Liqquid's Avatar
part of a wedge collar there (a.k.a, the clutch clip/T.O.B. clip)
Old Nov 14, 2011, 06:49 AM
bnr34rb26dett's Avatar
i believe i met u at the track. VIR. im the asian guy with the black buschur.
A lot of good info here. i hope you found your problem.
at least your transmission didnt go
Old Nov 14, 2011, 07:17 PM
Well hopefully not. We'll see now...
Quick Reply: Please help. Car is broke and need ideas to get it moving so I'm not stuck...
