Street/Drag Trans setup
#33
For an evo - a little direction would be nice on a trans/diff setup for use with a higher HP application. This would be a 9 second evo build. Full weight, but I'm open to running a drag radial or slick. What companies would I contact and what kind of pricing is out there?
#34
I had my tranny built by sheptrans and they were great to deal with. I have the evo 9 1st and 5th. They are very helpful and had great turn around. I would like to deal with more people like sheptrans when it comes to service/buying parts. just my 2 cents.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
#36
I currently have a shep trans and after spending 2 k . It's more notchy than stock. Yes shep went 7s and thats wild but My car doesn't go 7s. It is daily driven and I just need it to shift smooth and take the occasional wot runs on my favorite roads. Now debating on who I am going to get to rebuild it.
#37
1 Post
my opinion on best driveline setup for drag racing, you can agree or disagree with me is TRE Stage 2.5 with evo 9 1st evo, evo 8 3rd and 4th gear with HKS 4.11. Add a built shep 04 RS non lsd transfer case with a quaife diff and AWD Aluminum D2 driveshaft and youll have one of the nicest drivelines and great setup for drag. Just my .02. Best of luck with build.![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
OP, like others have said in this thread...call around...talk to all the suggested trans companies...Tell them what your goals are for the car & what it is used for...They will make some suggestions & give you pricing. Make sure to ask the different trans companies what clutch & gear oil they "recommend" to use with their trans. Good luck with your purchase!
#38
#42
This will pretty much be my exact setup except I have a Shep trans with IX 1st & 5th gears, VIII 2nd-4th gears & 4.11 final drive, billet output & other goodies...Sending my non-acd t-case to Shep soon for his stage 2 with a Quaife diff...AWD driveshaft is in the garage...Still trying to decide on a clutch though.
have you thought of having the jdm 5th gear ratio?
WTB[Northeast]: Wtb Evo 8/9 5 speed transmission
manthny18
Apr 4, 2017 03:09 PM
.DoT.
23
Jul 4, 2014 09:46 PM
