Can a HTA GT3076R make 500whp on Pump safely?
I just finished up tuning the setup in my sig, and it's a bit laggier than I feel like dealing with all of the time. Yes, it pulls like a train, however, I'm seeing full boost at 4800rpms and would like some more kick down low. My power goal is to be around 500awhp (Dynojet) and I can only run pump gas.
i have a full-race single scroll hta3076r with a .82 hotside with hks 280's, driven innovations intake mani and hks fcon v-pro... didnt make 500whp on my stock block, but i sure love the way the power kicks in and keeps pullin to red line. Def 500whp on meth or c16... i will look into a 2.3 in the future :-)
I'm making 445whp dj @ only 7000rpm atm with the gtx3076r (bolt-on style) with no cams/springs or headers yet on 93oct. I'm sure you can hit 500whp with S2's and headers with the HTA GT? What whp are you currently running with your setup?
HTA3076 on a stock 2.0L with stock intake manifold and S1s-
https://www.evolutionm.net/forums/ev...e-hta3076.html
With more boost, 93 octane, bigger cams, and a Magnus it might be possible to get closer to 500whp as a dynojet but it would be asking a lot on a 2.0L. On a bigger motor where the same airflow can be had at less boost, definitely.
I got to thinking about it after I typed that response. This is a stock head as well and tuned rich to keep it happy on the road course. I didnt push timing nor the AFR so there is more left in this one at 26psi if I was looking to make max power on the street. Your motor with S2s should make more anyway, the compression on pumpgas might mean a sacrifice in timing though. Hard to say until you do it I guess.
Aaron
Aaron
Aaron
Aaron
26psi and 25psi redline. this is on an X (as per sig) but 8/9's generally seem to make better power on similar setups.
