Synapse BOV issue
#32
It will become apparent when you consider the response differences and how well it holds boost. I didn't believe it myself until I was retuned. I have never had any boost holding issues with the Synchronic. I have been through several stock style BOV's including (Tomei, stock crushed and Dejon modded ).
#33
#34
In your case maybe so...
I have seen several instances where the stock style BOV's acted like they leaked boost. In fact there are posts on this forum that present this. What fuel do you run? What boost are you tuned to? I also noticed you are running a 3-port BCS as am I. Is the OP on a stock BCS? These are all things to consider and can vary the response this BOV has on each application.
Like I said...This BOV is a good one but does not have an identical response for everyone that uses it. Just trying to provide "out of the box" suggestions.
#35
OP is on an MBC if I'm not mistaken.
#37
Bov help
I see some here are having similar issues as me, I had a turbo xs(something like that) bov but was recirculated. Got 1250cc injectors, BC cams, MBC, high flow fuel pump, and got it street tuned after installs. I bought the synapse synchronic bov and installed it to VTA, hooked both ports A & B up(no port C on bov) and preload screw all way out, ran like ****, moved it almost all the way in and idled a little better but still skips from 1k to 3k rpms, made real small adjustments to it but still want to stall and skip through the low rpms...I am quite new to this, have a few buddies who help but need more experienced help!! Do I need both ports A & B hooked up? Or can I hook just one port up at a time and try it without hurting anything?..,or is there something else I'm missing? Lol....remember I'm new to all this, so any help would be greatly appreciated!!! Thanks!......also I'm running around 25lbs of boost on stock turbo
#38
No you don't need both ports hooked up. You can try just going to port A see if that helps then swap and try just going to B. I got mine to run better but not perffect. I ended up going with the TIAL in the end. I did like the spool beeter with the synapse... Also I swapped my vacum line coming off the IM to the BOV. I did away with the hard pipe and ran one vac line direct to the BOV.. Just another thought. Let me know if you want any other help
#41
Yeah it is weird...another question tho, I still am using the stock MAF sensor and air intake system, would I need to eliminate the MAF sensor, add a new air intake and change to like a speed density setup to VTA? Guess I should of added that part too
#43
Going with the SD, seems to be the better route for me. Hopefully in couple weeks after its done it will run better, just recirculated the bov for now so can actually drive it. Thanks for the help tho I appreciate it!
thedru13
Oct 16, 2013 07:45 AM
thedru13
26
Apr 26, 2013 09:29 AM
