Can't get engine and tranny separated.
ya its really not that hard.. i can get them off and on in 30 seconds. the trick is having a very big flat head, twisting the screw driver and yanking on the clutch fork arm.. it comes right off with that procedure unless its physically damaged and cant be separated. then you back out the pressure plate bolts like stated in the previous posts.
Got it!!
what i did was i bolted it back to the engine and then i left the clutch fork in the middle put the screw driver in the right spot (bottom of the cone) twisted, and pushed the TOB towards the slave and then as hard as i could away while twisting and jiggling, if i did it again it could be done in 30 seconds
anyone who has trouble with this isn't doing it right, it's just confusing the first time i promise
i spent 3 hours fighting with it but i get it now... lol and the Service manual is no help at all
Thanks guys,
Jabu
Thanks guys,
Jabu
Got it!!
Thanks guys,
Jabu
Thanks guys,
Jabu
SaulHudson
Nov 10, 2017 06:35 AM
coastevo
61
Jun 12, 2011 07:38 PM
