We need a HTA3586 vs 6266 comparison!
I've preferred Forced Performance turbos for the last 10 years, but this new 6266 seems impressive. Most likely I'm going to use a V-band HTA3586 but haven't ruled out this new Precision turbo yet. I've read plenty of discussions on FP quality vs Precision and can't really determine a clear winner. If you have any data to support your preference between these two turbos, post it here!
I'd go 6266 for a 2.3 setup. I wouldn't even consider going HTA3582. A 6266 will be a little laggier than the the HTA3586, but I 'think' it will make more power. Buschur Racing went 9.04 on the HTA86 and 9.1 on a 6262. AWD Motorsports went 8.9 on a 6262. I would only assume the 6266 would make more power with a little bit more lag. I wouldn't be worried about lag since you're running a 2.3. I'll be running a 6266 on my 2.0 very soon.
3586 and 6266 make similar numbers with similar spool. The 86 will still come out on top though I feel based on the testing I saw with an Evo X. Then there is the issue of the ceramic ball bearing center section and its lifespan. I know any turbo can and will fail but it seems I hear about far more Precision stuff.
Aaron
Aaron
What about the new 6262 CEA that looks on paper the best option? Quicker Spool + More Power.
HTA86 and "old" 6262 with the right options were Very Similar and i can't see why a 6266 would be worth having as how much more power can you squeeze from a 62mm wheel, i always thought the 6265 was deemed a flop?
