Piston slap causing knock sensor to go off?
Just finished changing a headgasket on my car which overheated. Car runs good, pulls good vaccum, compression is good but my knock sensor is getting faint readings on the engine. I can only describe it as piston slap. When the head was off, one of the pistons seemed a wee bit loose to where I could move it a tiny bit it I pressed it hard enough. Is piston slap enough to make the knock sensor go off on the AEM?
The ECU supposedly does filtering of the signal it gets in an effort to discriminate between knock and normal noise. On the other hand, I noticed that when I dropped the hood on my engine last night, the idle momentarily dropped.
I'm not 100% sure it is piston slap without tearing apart the motor again. I just meant the general vitals are all good. ie. compression, vaccum, etc... I'm gonna get a stethoscope and try and pinpoint where the noise is coming from.
Piston skirts to make sure they hadnt collapsed from the heat/lack of lubrication
Rod bearings
Valvetrain noise
I wouldnt run full power before you take it and log some low boost pulls. Since this an AEM I would be interested in seeing what the knock voltage actually is
remusrm
Dec 2, 2016 02:57 PM
wickedep
14
Jun 22, 2016 02:43 PM
yourSpecialisT
Jan 5, 2012 09:59 AM
