Car Runs Bad After Head Gasket Change
Old Jan 1, 2012 | 09:49 PM
Blue91lx's Avatar
Well,
I bought an Evo in the summer and haven't stopped having problems with it. The head gasket blew because the car overheated because the previous owner installed the thermostat in upside down. So, H11s and a new Mitsu Gasket went on, as well as a new thermostat.
The work was done by a professional shop, not myself, as the event happened with the car 6 hours away from home. My buddy picked the car up for me (as he was out where the car was located), and immediately reported the car ran like crap. Unstable idle, extremely low power, stuttering and hiccuping under any load. The car was professionally tuned and ran PERFECT before the head came off. I don't know what it could be.
The timing is on.
Vacuum lines look good.
Any ideas? I want a reliable car, and this thing has been the furthest thing from reliable since day one.
Old Jan 1, 2012 | 10:11 PM
kimma's Avatar
either your oil pump or cam position sensor is 180* out..run a search.lots of data on it
Old Jan 1, 2012 | 10:44 PM
triple L's Avatar
good luck n keep us updated
Old Jan 2, 2012 | 09:46 AM
Blue91lx's Avatar
Yeah....I know. I'm asking a solution to my specific issue. I've went through this 3 times. If the cps is out 180 the car won't run. Oil pump? I'm not so sure that it could be that....
Old Jan 2, 2012 | 09:47 AM
Blue91lx's Avatar
Thanks man.
Old Jan 2, 2012 | 12:03 PM
tsidrift1's Avatar
was the head checked for warpage? was it decked? Sounds like you might have a leak between cylinders. Buddy went through the same thing on his dsm. Do a compression check, see if one of the cylinders is abnormally lower than the others.
Old Jan 2, 2012 | 08:29 PM
Blue91lx's Avatar
Will do. Head went to the machine shop and was decked, as it was a tiny bit warped. I found a broken ground on the cam sensor, and also think that my ignition timing needs to be resynched with the AEM. I'll post up what I find when both are fixed.
ES Lancer
Lancer Engine Tech
Jul 11, 2016 05:03 PM
lghtngyello03
Mar 19, 2016 04:25 PM
mindoftw
Feb 20, 2016 06:09 PM
turbotaloon95
Feb 10, 2016 07:47 PM
drmcstford
Lancer Engine Tech
Dec 22, 2015 07:57 AM
Quick Reply: Car Runs Bad After Head Gasket Change
