Talon Manifold on Evo 8?
Guys,
When I had my Talon, I had a pacesetter manifold that I was very happy with. I was wondering if the bolt pattern on our block is the same as a 92 Talon TSi.
I ask this because I will most likely go through with that manifold if it does.
its been done several ways. like one inch spacer and eliminate power steering and move alternator to other side of engine. custom headers are another way. best way is the way I did it using evo X setup instead. here is link to guy with 8 conversion. I linked my setup in there as well..https://www.evolutionm.net/forums/ev...-vr4-4g63.htmlp
You know the Talon rocked a single scroll 14b and the evo 16g is a twin scroll, right? I'm not positive but I would figure the airflow would get messed up. Plus the stock manifold flows better than that pacesetter. If you want a cheap tubular manifold, go Megan. Still doesn't flow better than stock.
