Gt35r parts?
Old Jan 11, 2012 | 05:30 AM
boostn6262's Avatar
Gt35r parts?
If i purchase a gt35r with the 02 housin and wastegate. What else would b needed to make this fit on my evo 8 besides t3 manifold. Would my upgraded lower intercooler piping fit? Would this turbo fit between block and radiator? Plz need info
Old Jan 11, 2012 | 05:46 AM
hamx0r's Avatar
That all depends on what manifold you are going with but almost all t3 manifolds are made to fit with stock radiator. And depending how your o2 housing is, you might need to modify your downpipe. For your LICP, if you were on stock turbo before then you might get away with just purchasing a new coupler for the turbo to LICP.
Old Jan 11, 2012 | 06:11 AM
boostn6262's Avatar
Yea this turbo comes with a vband housing ill just have it modified to my dc sport downpipe. And for the intercooler piping mayb another bend of new piping and a coupler would make it work. Thanks guys
Old Jan 11, 2012 | 06:12 AM
boostn6262's Avatar
Were can lines and fitings b purchased?
Old Jan 11, 2012 | 12:34 PM
hamx0r's Avatar
http://store.forcedperformance.net/m...egory_Code=Acc
Old Jan 11, 2012 | 05:47 PM
fre's Avatar
fre
Yea you might also need a slimline radiator fan (on the inside of the radiator), as the stock one is a bit thick and might not fit. You already seem to have figured out the oil lines. I am not sure if I am using stock oil and coolant lines or not as I didn't originally install the turbo, but I know the coolant lines are silicone, so probably not stock.
Old Jan 11, 2012 | 07:07 PM
caLi4G63's Avatar
I've had positive transactions purchasing fittings and lines from the following two:
www.extremepsi.com
www.atpturbo.com
Good luck and don't forget to purchase extra copper washers and fittings; you can never have too many!
hutch959
14
Apr 6, 2016 12:42 AM
ryukinevo
Oct 18, 2010 07:30 PM
rebel
May 22, 2010 07:16 PM
xtremeboost
Southeast Region
Sep 10, 2007 08:47 AM
blackonblackevo
Apr 17, 2007 06:21 AM
Quick Reply: Gt35r parts?
