EVO rod weights
EVO rod weights
Hi All,
I read a post on here a while back that listed measured rod weights of different brands and types of rods. Can anyone point me in the right direction? I've searched and can't seem to find it now.
Specifically looking for:
- stock rod
- aftermarket I-beam steel
- aftermarket H-beam steel
- aftermarket H-beam 300M
- aluminum stock length
- aluminum 162 mm
- titanium
If memory serves correct, the steel H beam was heavier than stock. 300C and aluminum were close, and TI was about 100 grams lighter than either of those. . .
Thanks!
- stock rod
- aluminum 162 mm
- titanium
Thanks!
Thanks guys! That sounds about right. Any weights for aluminum rods or titanium rods? Seems I saw a post a while back with AL rods at around 500gm, and some TI rods around 400? Does that ring a bell with anyone?
https://www.evolutionm.net/forums/ev...inum-rods.html
Post 57 from Ted B amongst others.
There is also some data in my 2.2 thread I believe.
I can add some others-
Steel R&R
R&R 156mm I beam - 602g
R&R 159mm H beam- 568g
R&R 156mm H beam (discontinued for the most part)- 548g
Steel R&R
Stock = 695 grams
Aluminum:
GRP = 470 grams
Map = 470-480 grams
Groden = 490 grams
R&R = 500 grams
All other material:
Crower titanium = 410 grams
Carrillo = 520 grams
Engine pro = 557 gram
Manley H beam = 573 grams
Eagle = 575 grams
Oliver = 605 grams
Pauter lightweight = 610 grams
Crower = 612 grams
Scat = 640 grams
Map billet rods = 652 grams
Pauter = 685 grams
Manley I beam = 690 grams
Aluminum:
GRP = 470 grams
Map = 470-480 grams
Groden = 490 grams
R&R = 500 grams
All other material:
Eagle = 575 grams
Oliver = 605 grams
Crower = 612 grams
Scat = 640 grams
Pauter = 685 grams
Steel R&R
Steel R&R
H beams are rated at something like 190 per cylinder nominal, I beams are rated at 300 I believe. I will have to call in the morning on the I beams, the H beams I know are rated correctly. As far as that goes though, the GSC I am running arent as heavy as the R&R H-Beam and I made over 800 on them. Remember tune is everything.
