HELP!!! engine breaking up at higher RPMs
Alright here's what's going on, I'm having an issue with my car breaking up around 4500 rpm.
Mods:
EVO 9 turbo
Stock Injectors
HP MBC (17psi)
3 in TBE
Custom Intake
TIAL Q (vta)
FMIC with all hard piping
COMPLETELY STOCK ENGINE
93 oct
NGK bpr7es gapped to 24
The car is flashed with Tephra V7 and the tune that is loaded on it is running in about 4 or 5 different cars without any issues. I'll accelerate it pulls hard up until about 4500 then in bucks (no CEL flashing for knock) i stay into it, it pulls just the same until about 5500 bucks (no CEL flashing for knock) about 6700 bucks again but pulls just the same. I'm super confused as to why it's doing this, I do have a small pre turbo exhaust leak but I wouldn't think it would be major enough to affect anything. I know that the TB shaft seals have been replaced with mil spec seals and there's no sign of any boost leaks...help me please
Mods:
EVO 9 turbo
Stock Injectors
HP MBC (17psi)
3 in TBE
Custom Intake
TIAL Q (vta)
93 oct
i'm going to check again tonight for leaks...im not sure what i should change in the tune, i have everything to change it IE: evoscan, ecuflash. Someone help with my tune LOL
id say its a tune issues myself also..but have you checked your plugs to make sure for whatever reason your not haven a ignition issues ? as already stated check vacume and boost connections. honestly who uses genaric random tunes? i hope a tuner can clue me in on this but do you guys just back log a bunch of maps n reuse them on multipal cars? i was under the impression each car needed to be tuned specific..
(Now my background is mainly DSM n im trying to learn more on Evos so excuse me if i say somethin wrong)
I know you say your motor is stock but you have a larger then stock turbo n more then likly boosting more then stock, your list says custome intake, intercooler hard pipes and your BOV is VTA so are you convertered to SD or closed loop on just a reflash ? cause the velocity of your charged air is going to be higher then stock so wouldnt that mess with the MAP readings ? if the engine is seeing more air then normal its going to try to compensate with more fuel but in this case not sure how much to add ? in also doing so what about timing? isnt the bucking usual a sign of a timing issues ?
Mods:
EVO 9 turbo
Stock Injectors
HP MBC (17psi)
3 in TBE
Custom Intake
TIAL Q (vta)
93 oct
Mods:
EVO 9 turbo
Stock Injectors
HP MBC (17psi)
3 in TBE
Custom Intake
TIAL Q (vta)
93 oct
