At what point does the stock FPR become insufficient?
Old Jan 26, 2012 | 12:47 PM
icrnk's Avatar
Originally Posted by Freddie@Spec-Ops
A rewired 301 most often overruns the OEM FPR... however the fuel pump test Mrfred just did with the 255, 301 and aeromotive pump pretty much negates the need to waste your money on a 301...
What if one doesn't want a 255 due to the noise? Is a 301 or the Aeromotive on stock wires a suitable alternative? Don't mind paying more for a quieter pump.
Old Jan 26, 2012 | 01:04 PM
tscompusa's Avatar
icrnk i take it you don't have an evo then? because you shouldn't be able to hear a walbro 255 at idle in a evo. your profile says mirage so im gonna assume its a mirage.
if your goal doesn't require more then a dw301 then go for it.. id take the DW over the aeromotive any day of the week if i had to choose between the two.
Old Jan 26, 2012 | 01:11 PM
icrnk's Avatar
Have an evo ix, just never updated the profile. I'm on stock pump but will probably need to change after next round of mods. I'll be on 93 and stock cams and probably will go for fic 1100 or 900.
Have ported exhaust/intake mani, O2, hot side. Turbo back. May add ported tb.
Old Jan 26, 2012 | 05:54 PM
Spec-Ops1's Avatar
Thw walbro wine really is hit or miss... some have it some dont... my old pump was super quiet, the new one is a tad *****y
Old Feb 14, 2012 | 06:24 AM
Levar's Avatar
Veteran: Army
Originally Posted by Mikey@Spec-Ops
I don't have a problem with my stock FPR. 9 times out of 10, most people don't need to upgrade their FPR.
...however the fuel pump test Mrfred just did with the 255, 301 and aeromotive pump pretty much negates the need to waste your money on a 301...
Davids bad bish is on stock FPR also. theres lots of high hp evos on stock fpr.
The thing about these sorts of threads is that when I learn new stuff, I makes me happy but at the same time I am forced to sell parts that I see are no longer needed or necessary. It looks like I might have purchased an AFPR prematurely not to mention the DW301 fuel pump that are both sitting in my garage. Dang.
Old Feb 14, 2012 | 10:11 AM
Blue91lx's Avatar
Exactly. I love when real world results are posted from these guys (especially English and Spec Ops), rather than the million opinions on the board that don't really mean much.
Old Feb 14, 2012 | 10:18 AM
Levar's Avatar
Veteran: Army
But it is always after I but the parts that I think are winners.
Old Feb 15, 2012 | 02:28 PM
Levar's Avatar
Veteran: Army
So..., is the Walbro 400lph capable to flow enough to make +600whp on the stock pressure regulator, stock lines, and without a re-wire kit?
Old Feb 15, 2012 | 10:09 PM
burnzy's Avatar
my 400 flowed less than 255 until i rewired, guess it drew too many amps.
Old Feb 16, 2012 | 06:48 PM
sparky's Avatar
....is the Walbro 400lph capable to flow enough to make +600whp......without a re-wire kit?
What fuel are you gonna run?
Old Feb 16, 2012 | 08:44 PM
Levar's Avatar
Veteran: Army
My friend, I will be map switching with pump/91 and E85.
uranium9v
Lancer Engine Tech
Jul 9, 2016 09:05 AM
Grip Master
32
Sep 18, 2015 02:09 PM
gavi101
May 24, 2015 02:43 PM
RSGuy
14
Jan 21, 2013 10:48 PM
m7mad.a
Mar 4, 2012 06:33 AM
