Im seriously considering a VNT conversion on my turbo
In Timeout
They have a lot of problems and can not boost that high, used to have a NSX and people who had them replaced them all the time.
Originally posted by Mister2zx3
http://www.aerocharger.com/
Twin Variable Vane Turbos on an NSX is wickedly fast. KInda makes the world bend around you. incredibly linear as a stock NSX, but with painful amounts of thrust.
Just go back to the original source John.
Check this turbo options list.
http://www.egarrett.com/products/gt_30_45.jsp
Alex...
Alex...
In Timeout
lolrof, I don't think John likes to think.
Alex...
Alex...
alex...You ARE the man....Im gonna see about this tomorrow...
the GT35r VNT would be sick....this turbo is insane...VNT would make it incredible...this car would feel like it had a big block in it
Ryan..I think too much all day....Im burned out..
In Timeout
I heard that, try daytrading futures all day
for any csx questions ask alex...he has a eally nice 87 csx ( it had a very handsome owner prior to him) and he has been with the shelby dodfges for years now.....
alexi still crave that glhs
Im in a good mood...I wanna make my evo better
Does the VNT turbo use a seperate computer to control the vanes that open and close in order to vary the pressure to spin up the turbo, or was it some sort of vacuum/boost solenoid? I remember the concept and if memory serves the were several vanes around the exhaust houseing that pivoted to control the flow. I just don't know how you would control the vanes?
If you try to get a turbo that big to spool any faster, chances are you will just run into compressor surge instead. Remember that you have to stay to the right of the surge line with respects to your operating point.
As far as I know, VNT turbos have issues with reliability.
You are searching for the holy grail. Nobody has found that, either, btw.
you will always have a problem with spool up on large turbos, its simple phisics, larger masses take longer (with same force) to accelerate. So the solution is to make lighter turbos (thats why Mitsu use Ti and ford racing used ceramic turbine blades!), reduce friction (ballbearings, ceramic if poss) or just creat more force (ANTI-LAG, hehehe). Speek to Norris Design in the UK, i read a report on his car and it was said that his 500+BHP motor had no lag at all!!!!!
