Worth getting upper and lower IC piping
Just wondering if IC piping make a noticable difference in performance? Also, will it void warranty?
from what i understand, unless you are going beyond like 350whp, its not really necissary...after 350 you have to upgrade the turbo anyway
so you will be doning alot more than Ic pipes
well..if thats the case.
could someone please explain how the buschar stage 2 kit is producing almost 50 hp more with the only differences between the stage one kit being the upper i/c and maf pipe??
Shorter intake tract means better throttle response.. also, shorter, larger pipes, etc means less restriction.
I think the gains are pretty much dependent on what other mods you have, but the more air in and out, with the least amount of restriction means more power..
The gains are real, but its the combination of parts more than just the pipes that made the dramatic difference. I also suspect that the gains for the stage1 components are underrated which makes the stage 2 gains look more dramatic.
FS[SouthEast]: Evo 9 oem i/c piping
hutch959
Oct 10, 2016 05:48 PM
David24
Sep 25, 2009 10:05 AM
svt1.8t
Jan 9, 2009 11:52 AM
