2.5" downpipe w/ cat delete for EVO IX?
Does anyone know if there is a 2.5" downpipe available that has the cat delete? Looking for a one piece dp for my EVO IX MR.
Thanks.
Thanks.
Stock is 2.5" from my research. The catback is pretty well designed, mandrel bent, not terribly restrictive. I figure, if I replace the downpipe and substitute a test pipe for the cat, that will flow plenty to meet my power goals - and remain reasonably quiet. I understand and accept I may lose 8-10hp at peak, but I should pick up 15-20 by going this route.
I'm aiming for minimal mods at this point. Downpipe and test pipe alone should flow well enough to support an endstate of 320whp. Working on figuring out the other required mods, just happened to start here with the exhaust.
Uh...the catback is restrictive...I don't think you'll pick up 15-20 by going that route.
If you're worried about noise get a good quality catback with a high-flow cat or the stock cat
Jhurley_EvoVIII
Sep 11, 2015 08:22 AM
EVO VIII Chris
29
Oct 1, 2014 07:51 PM
Sourav mahmud
Apr 16, 2013 09:46 AM
TomeiEvo
32
Feb 4, 2005 10:43 AM
