ACD fluid level does not rise up after car sits for while.
I know the level of fluid drops when the car is running and after it sits for a while the fluid level goes back up as fluid returns to the reservoir. But in my case, fluid level does not rise up after car sits for while. Actually, fluid level stays same before/after drive around. I tested ACD pump this morning manually and it worked fine. I don't know if freezing cold weather affects this? It was like 20 degrees outside lately. Also, I recently installed JDM headlight. Did I blow some fuses? Is there anything I should check? Many thanks to you guys and hope it's not serious.
This morning
![](http://i454.photobucket.com/albums/qq268/evoixryu/IMG_8904.jpg)
Positive battery fuse. I heard 60A fuse relates to ACD pump operation.
This morning
![](http://i454.photobucket.com/albums/qq268/evoixryu/IMG_8899.jpg)
^ thanks guys. I remember it always went back to max level before installed JDM headlights. Is there any chance I messed up ACD unit during headlight swap? such as wires. Coule be coincidence but...
I drove to work now and no 3 acd lights. Our of curiosity, is there any reason why ACD sucks in and out the fluids? I hope my acd does not break due to not realeasing fluids.
When the pump starts working it pumps fluid into the accumulator so that the acd doesnt always rely on the pump for its acd pressure. So the fluid level drops because its being stored in the accumulator. When the engine stops it grqdually releases its fluid back to the reservoir.
^thank you so much for great info. so what happens if accumulator is shot and does not do its job? How does it affects on acd unit or acd pump? Sorry. I am trying to prevent worst case scenerio.
I recently did a clutch swap so the ACD was drained. After filling it up and bleeding the line this is something I watch closely. When cold the level sits on MAX and after driving it sits on MIN. I don't know how long it takes to rise after being parked, but not more than a few hours.
To test the pump turn the ignition to the on position and then press the throttle to the floor and hold. After a few seconds you will hear the ACD pump kick on for ~5seconds. On my setup this draws down the fluid level slightly, but not from Max to Min.
^ thanks for help. Yea, I did pedal method and I could hear pump is running fine. No ACD 3 lights during drive. Only problem i have is fluid is not rising back to max level after car sits for while.
I took picture right after I came to work around 2:00
![](http://i454.photobucket.com/albums/qq268/evoixryu/IMG_8915.jpg)
Took picture around 4:30. Level stays exactly same.
![](http://i454.photobucket.com/albums/qq268/evoixryu/IMG_8931.jpg)
I did not bleed. All I did was push pedal all the way down and put ignition to on postion. I heard pump was running for like 3-5 seconds. Isnt that how you test if pump is running ok?
Yes but to test the whole system you should try bleeding it. The pump should run for 5-10 seconds then stay off for around 30 seconds while you have the bleeder open and are draining fluid. The pump doesn't need to run constantly even if you're bleeding because of the accumulator. If the pump keeps running while you bleed it might indicate a problem with the accumulator. If there's no fluid coming from the bleeder it may point to another problem.
