4inch Downpipe & 4inch Aluminum Exhaust
Here's a few pics of some things we're doing to bring the car out with even more power this spring.
*4inch downpipe (304 stainless)
*4inch aluminum exhaust
*4inch aluminum Vibrant muffler (this thing is light)
V-band from front to back on exhaust for easy removal.
Probably saving 75-100lbs just in the exhaust system.
Also, doing aluminum intake piping to intercooler and from intercooler to throttlebody.
GO HERE TO SEE SOME DYNO RESULTS - https://www.evolutionm.net/forums/ev...gear-pull.html
can we get more info on this car so the people like me do not post like i am about to below. we need more info on this car otherwise
why are you doing 4 inch exhasut? from 3 inch to 4 inch under 900hp your not gonna gain anything. so thats added weight you do not need. if your over 900hp a 4 inch exhaust is still not needed on an evo unless your planning to run 1200+ IMO.
if this is on a Evo there is no way your going to drop 100lbs on just an exhaust.
the pictures look like it is his own evo...the bby and the way the lower radiator mount is setup, if we're right, and it is his 2003 Evo...theres no way it would be a 75-100lb difference from ANY exhaust system, even the factory exhaust wouldnt be anywhere near that.
you might need to re-calibrate that weight scale...
id say you'll maybe save 10-15lbs versus an aftermarket setup like a greddy tic, ams, or buschur catback...and even then i highly doubt it would be that big of a difference.
nice try though...
and as for power gains...gotta agree again with evodan2004, if the setup isnt able to make 900+whp i dont see you gaining too much from it...it will be loud as hell though.
the bends look good so far...lets see some finished results.
Interested question on 4" downpipe, having a s400sx turbo, and doing about 1000 whp, would a 3" restricted exhaust system work on my setup? S400 has 4" native exhaust, actually i use a short pipe without going under the oil pan, but a little less noise would be a great thing....
THIS. +1.
nice try though...
nice try though...
My car made 780whp on a Mustang dyno last year through 3inch exhaust. That equates to about 900whp on a Dynojet if you use the average 13% higher reading that the Dynojet will give. We were beginning to see the results of back pressure as the boost got turned up to 40+psi. This exhaust will definitely allow us to make more power, and will allow us to do it easier.
So, you can agree with Dan, but I'll ask you both this - How much horsepower have you made through a full length 3inch exhaust? What is your personal experience with this? Or, are you just a pro from reading what others tell you here on Evom?
If you ran full length 4inch to the bumper, you may see the same results as your short 3inch pipe you are currently using. Spool up might be a little slower with the longer piping, though...
