Turbo XS RFL bov
I had mine aimed up towards the hood vent, and when i would rev it up and it blew off you could see the hood vent go up and then back down, it was pretty cool. And can any tell me what compressor surge can do, because i noticed it too when i had it on, no matter how many washer were in it.
Re: here's my pic
the vacuum line im using is alot thicker than a stock hose and 5 inches longer (with the thicker hose its hard to use the stock clamps) no kinks of any kind, i did take another vid of me around 3k punching it then letting off then punching it the letting off to 5k but i will take a vid of what you where talking about btw anytime ive ever revved it to 6500 and let off the gas it jerked
Originally posted by ytsejam
here's mine....
notice that mine is far away from the fan...that's because i have a shorter elbow hose.
here's mine....
Well i took on the process of taking the cone off and modding it to dump back into the air box. It was very easy, took about 30min. and all u need as stated before is a 1 inch threaded pipe. Put it in a vice, wrap a rag around the cone, take a off with large pliers, switch pipe, i used plumbing tape just to be safe for no leaks, works perfect, and is pretty loud, but i do have the cone intake so that helps. I have pics of the process and after probduct if someone can please host them for me.!!!
thats the same as the bov rnr sells for cheap! i was just looking for ultimate loudness!!! also i have a new video of me at high rpm letting off and its smooth as a wistle!!! (the ftp is down right not though)
yea came on for about 6 hours 4 that night 2 in the morn. and turned off, havent had it since then about 10 hours of driving since then i have full 3" test pipe and jdm tip
