Broke some studs out of my fuel tank. help?
Like the title says, I broke a couple of the studs from around the fuel sending unit. It won't seal now. Is there a way to fix this or am I in the market for a new gas tank now?
The shanks are still in hole? There are tools called easy out or screw extractors, made for taking stuck screws/bolts out. If you are the DIY type you could try this, or take it to a shop that is willing to do this. You drill the center of the bolt, put an easy out in vice grips hit it with hammer while turning the vice grips. The easy out will bite into the screw and you should be able too take it out.
I suggest taking it to a shop to do this though, most turbo shops should have the tools since they usually have to remove bolts from exhaust side and turbo flange.
jrsimon27
39
May 25, 2022 04:26 PM
Ryu123
Mid-Atlantic Region
Jan 11, 2013 04:09 AM
